Roof racks ....again.....
tomynoks
PostPosted: Sun Nov 26, 2006 6:54 pm    Post subject: Roof racks ....again..... Reply with quote
Phantom....
In previous threads you've said that you wouldn't buy a rack that mounts to factory cross bars.. (I think) yours mounts to the factory rails though... right?? I have a '99 XJ... they shortened the rails that year to 50" ... Do you think it'd be easy enough to mount some pre-'99 rails so I can get a longer rack?? Seems simple enough, but I always like to check with those of you w/ more experience.
Anyone else too??
'99 XJ Sport
AirAid Intake
PowerAid Throttle body spacer
RE6030 3.5"
1" T-case drop
31x10.5x15 BFG AT KO's
tomynoks
PostPosted: Tue Nov 28, 2006 7:55 pm    Post subject: Reply with quote
Anyone?????????
'99 XJ Sport
AirAid Intake
RE6030 3.5"
1" T-case drop
PostPosted: Wed Nov 29, 2006 10:12 am    Post subject: Reply with quote
The side rails are held down with screws. So to put longer rails on, you would need to drill some holes in the roof and make sure everything is watertight after the new (longer) rails are on.
Another option is to get a rack that mounts to the rain gutters instead of the existing rails.
tomynoks
PostPosted: Thu Nov 30, 2006 1:36 pm    Post subject: Reply with quote
I just bought a longer rack... came off of a '94. Mounting to the rain gutter seems more stable though. What's your opinion?Also, if I mount the longer rails, how would you suggest I attach it? I mean, I know with screws, but should I maybe put some RTV on the rails as well to keep it water tight?
'99 XJ Sport
AirAid Intake
RE6030 3.5"
1" T-case drop
flycracker
PostPosted: Wed Dec 06, 2006 7:19 pm    Post subject: SEAL THAT RACK! Reply with quote
I HAVEN'T DONE THE EXACT PROJECT YOUR TALKING ABOUT BUT I BEEFED UP MY STOCK RACK BECAUSE IT WAS REALLY LOOSE. I BACKED OUT ALL OF THE SCREWS AND REPLACED THEM WITH HEAVY DUTY RIVETS. BEFORE THE APPLICATION I SEALED ALL OF THE HOLES WITH A MARINE SEALANT(COMES IN A CAULKING TUBE @ HOME DEPOT/$10). WHAT YOU'LL NEED TO DO IS GET THE RIVET HOLES LINED UP AND CAREFULLY DRILL ANY NEW HOLES THAT YOU'LL NEED AND THEN CAULK, APPLY RIVETS FROM ONE END MOVING TOWARDS THE OTHER. YOU CAN GET A KIT TO MOUNT FROM THE GUTTERS BUT I DONT THINK IT LOOKS AS "CLEAN"...ANYWAY, HOPE THIS HELPS!
tomynoks
PostPosted: Wed Dec 06, 2006 8:32 pm    Post subject: Reply with quote
Thanks Fly.. I'll take your advice for at least part of it. I'm not sure if the existing holes on my '99 will match up with the holes on the long rails from the '94, if they do, I'll use the existing screws and holes then rivet the front end.
'99 XJ Sport
AirAid Intake
RE6030 3.5"
1" T-case drop
