May have located wierd idle problem..Please chine in all...
rtlofishing
PostPosted: Thu Nov 30, 2006 7:31 pm    Post subject: May have located wierd idle problem..Please chine in all... Reply with quote
I put on a new IAC which i knew it needed and also put on a new TPS which did nothing for my problem..I got my can of throttle body cleaner out and started spraying all my vacum hoses down and noticed on 1 side the idle would drop down when the cleaner would run and puddle up at the base of the intake and after repeated sprays,got the same results..My engine has high miles so is there a good likely hood that my intake gaskets are leaking??????Causing my off idle slight stumble...Can i test this with a vacum guage before tearing all this down to do a full intake gasket set???? What should the guage be doing if my intake is leaking?Thanks guys
PostPosted: Fri Dec 01, 2006 6:01 pm    Post subject: Reply with quote
Plenum gasket is probobly bad as well ... Pop it off and put new gasket set on it.. Plenum and intake and throttle body.. Its not that hard.. take your time so you dont brake any injectors or pigtails...
