window sprayers
BlueSunday
PostPosted: Tue Nov 21, 2006 8:39 am    Post subject: window sprayers Reply with quote
Ive got an 88 comanche and one day about a week ago i tried to use the sprayer to wash my windows...the wipers go but theres no spray....im assuming its gotta be the pump....is it sitting right underneath the resivour? whats the replacemnt runthrough?
kloker
PostPosted: Sat Dec 09, 2006 1:38 pm    Post subject: Reply with quote
It could be any of several problems. Try this: Have someone actuate the sprayer while you get your ear close to the pump. If it's operating, you should be able to hear it easily, or feel it working. If you don't, it might be bad, not that uncommon. But, it could also just be a fuse or a loose or disconnected or damaged wire or plug. Check to see if it's getting power.
If the pump works but you get no spray, trace the little hoses and look for a problem there, like unhooked, broken, cracked and leaking (no pressure) or possibly even clogged. If all that is good, then the spray nozzle(s) may be clogged. You can blow them out with air pressure.
I haven't had this problem on my Cherokee, but I've had it with other vehicles. Once it was the pump. Other times the nozzles were clogged. And one time there was a dead bug clogging up the little screen at the bottom of the reservoir. Stupid bug. Mr. Green
