New guy here...Need help with Stereo Install
SDale
PostPosted: Wed Dec 13, 2006 4:21 pm    Post subject: New guy here...Need help with Stereo Install Reply with quote
First off... FINALLY I find a place for Jeeps that isn't all about rock crawling & off-road!!! LOTS of good info!
Now for the good (or bad?) part. I searched and the threads I found didn't really pertain to my situation and the FAQ's didn't say anything about it either.
99 Grand Cherokee Laredo, Non-Infinity Stereo (Stock Single Disc with tape player & 3 band EQ)
I installed a Used Pioneer Head Unit using a Scoche Harness. Matched everything up and turned on the Stereo. Weeelll, all the sound I get is REALLY distorted. Sort of like I'm playing the radio at a really high volume, but it's at ALL levels. Low volume, high, medium etc. I called Scosche Tech. Support and they were no help. Rechecked my wiring...it's all good. I can't seem to find the problem?
I bench tested the head unit and it works fine. All speaker outputs work fine.
Any help would be greatly appreciated!
DankNesS
PostPosted: Thu Jan 18, 2007 10:11 pm    Post subject: Reply with quote
my 93 came with a stock amp that i had to bypass... maybe this is your problem?? i found out witch wires were runin to it and.. didnt connect them... also i had this problem in my 200sx.. wires melted or some shiot.. SO i just ran all new wire from my deck to my speakers.. this also upgraded them from the shitty stock ones...
i just got done runnin new wire in my jeep to a new amp in the back with new speakers... i would go this route if it is possible.. my sytem is re-dic
