93 GC with Fuel Problems Won't start Need Help!
blacknight
PostPosted: Sat Dec 16, 2006 12:13 am    Post subject: 93 GC with Fuel Problems Won't start Need Help! Reply with quote
I don't post too often but I try to research a lot. I have a similar problem the oleshifty had on Oct. 17th post. I have the 5.2 engine with no pressure at the test port. I pulled the ASD and fuel pump relays and they have power constant and swithched. I'm not sure how to check relays with my tester. I also tapped into the power line by fuel pump and it had no power either. I have also been having problems with the security system as both drivers and pass doors disarm switches no longer work and its a pain to use the tailgate to turn off system. Any help would be appreciated as I'm getting frustrated.
blacknight
PostPosted: Wed Dec 20, 2006 12:39 am    Post subject: Reply with quote
I'm really disappointed in the lack of any replies to my problem. I was able to fix it without your help. It ended up being a bad fuel pump.
cajzmere
PostPosted: Thu Dec 21, 2006 3:13 pm    Post subject: Reply with quote
Sorry 'bro, I only check once every few days, and I think if anyone knew an answer, they would have given it. I've found the people here are really nice.
As far the alarm thing, people seem to recommend calling or going to the "stealership". The alarm system is hard wired into alot of different places. You might try looking at the wire bundle going from the door to the body, thats covered by a boot. This seems to be a point where wires chafe, ground against each other, and make power door locks and power windows stop working. E-bay has many replacement remotes available for sale too. Good Luck man!!
