Help need sizes for suspension bolts ASAP please!!
dubbleJ's
PostPosted: Wed Dec 27, 2006 10:48 pm    Post subject: Help need sizes for suspension bolts ASAP please!! Reply with quote
Im looking for the bolt sizes for all my 4L '90 XJ suspension..leaf bolts, control arm bolts, shock bolts front and rear, front spring retainer bolts etc etc...any sizes help!
Im doing my lift tomorrow out at a shop far away and want to try and prevent trips into the city!
flintlock
PostPosted: Fri Dec 29, 2006 2:43 pm    Post subject: Reply with quote
I just got done with my lift today, the rear bolts for the leaf springs are 14mm by 120mm
I believe the control arm bolts are the same.
We cut the leaf bolts off just to make things easy, but we only had one other bolt that broke and that was the shock mount bolt on the rear. If you use lots of PB Blaster it will help. Good luck
