Rocker Panels for 95 swb 2 door XJ - Do they exist?
2door4liter
PostPosted: Sun Dec 31, 2006 1:56 pm    Post subject: Rocker Panels for 95 swb 2 door XJ - Do they exist? Reply with quote
I'm new around here and need some help. I've searched here to no avail and have searched the rest of the internet (Yep, all of it.) with no luck either. I own a 1995 2 door XJ and need to replace the old rusted out rocker panels but I can't find any for the 2 door. I only find them for the 4 door. Has anyone else here had this problem (and solved it), does anyone have a clue how to find the right ones for the 2 door, or does anyone have any clue as to a possible solution of any kind? Thanks in advance. Will a 4 door set work? Will a 4 door set work if cut slightly? I'm stuck.
Thanks,
Toby
Tardis
PostPosted: Mon Jan 01, 2007 11:57 am    Post subject: Reply with quote
Replacement rockers exist, 2 and 4 door rockers are the same(see links). The only difference between 2dr and 4dr XJ sheetmetal is a bit shorter wheelbase on the 2dr's, and the presence of rear doors on 4dr models. Compare a 2dr XJ quarter panel to a 4dr with the last link below and you'll see what I mean.
Raybuck autobody parts Left rocker panel:
http://raybuck.com/wsm/i-10963_1984-96_rocker_panel_oem_xj_cherokee_lh.html
Raybuck autobody parts Right rocker panel:
http://raybuck.com/wsm/i-10964_1984-96_rocker_panel_oem_xj_cherokee_rh.html
84-01 XJ replacement body panels:
http://raybuck.com/wsm/c-143_1984-2001_cherokee_xj_repair_panels__body_parts.html
2door4liter
PostPosted: Mon Jan 01, 2007 12:48 pm    Post subject: Reply with quote
Thanks a ton. That was what I hoped to hear.
Toby
