need help! with 93 jgc
chevman-67
PostPosted: Mon Jan 01, 2007 9:50 am    Post subject: need help! with 93 jgc Reply with quote
happy new years everyone!
heres my problem I was driving and my 93 jgc 4.0 died! I have lost all power going to my fuel pump.Every now and then it will kick in but die right away.its a new pump .I have dissconected the pump and I have no power at the plug the relay seems to be kicking in and working .Im wondering if the inertia switch for the pump might be to blame.WHERE is it and can the computor also be the problem.the engine will crank but no fuel at all.it wont even kick in when i cycle the key on and off.what color of wire is it that should have power at the pump connector.ANY help is better than none as the wife has no vehicle to get to school or work.THANX.
1967 chev shortbox stepside
1988 gmc 4x4
1989 gmc 2x4
1993 jeep grand cherokee
cajzmere
PostPosted: Mon Jan 01, 2007 6:23 pm    Post subject: Reply with quote
Hey, check the swampy bypass for more info on fuel pumps. I have seen DOA straight outta the box pumps. Try hooking 12 volts to it direct and if it comes on, check fuel pump relay with known good one. Computer won't be the problem.Don't know color, but you can see pigtail coming out of top of tank under the truck. If you use "Search" function at the top of this page you'll get all KINDS of info! Good luck !!
chevman-67
PostPosted: Wed Jan 03, 2007 3:38 pm    Post subject: Reply with quote
Well shes going again . I spent alot of time on this 1 and started at the relay under the hood and began testing the electrical at the relay box and found the live feed wire Which is orange and blue and had a 2nd person for help turing the key on and off as the relay will only energize for about 5 seconds,and started to prob for power there are 2 orange and blue wires that go into the main harness out of the fuse box under the hood and both had power then went inside under the drivers side dash and had power there as well but the wire changes color there and is now orange with black then went under the drivers rear seat and tested the orange and black and power there as well youll also find the inertia switch there as well if you didnt know!Then went under the jeep to find no power at the plug and began testing the wire from the floor pan down and found the wire had corroded off (green death).about 2 inches from the plug cut ,soldered,shrink tubed,taped replaced loom cover, tapped again.works great now if this is a help to anyone other than me GREAT its not that hard but it sure is frusterating. Very Happy someone please post this in the right place so it may help somone else.
1988 gmc 4x4
1989 gmc 2x4
