detroit trutracs ?
langston
PostPosted: Sun Jan 07, 2007 6:31 pm    Post subject: detroit trutracs ? Reply with quote
i was goin to put a trutrac in my d44 rear. ive noticed that alot of people usually put them in the d30 front, or front and rear? is it still an ample setup for just the rear?
DankNesS
PostPosted: Tue Jan 30, 2007 4:52 pm    Post subject: Reply with quote
the problem with just locking the front or rear is this.. unless you have bags of money and like to buy multiple gears for the same axle of course Razz .. any way if you are going to lock the rear you should definately get a better gear ratio from stock especially if you are running bigger tires.. SO you cant just thro in 411s if you got 373s stock in front.. you need to swap both...i would suggest getting a good rear and save up and get a good front and install both at the same time.. that way you can have a better gear ratio and be fully locked... id say go cheap just to get it locked up then get better gears front and back one at a time.. but then you will already have lower gears so its all g! know wat im sayin?
