Temp Sender
gtouimet
PostPosted: Mon Jan 08, 2007 3:48 pm    Post subject: Temp Sender Reply with quote
So I got a trany temp gauge off ebay that did not come with any instructions. It was in great shape, but without institutions I don't know how to wire up the sender. It has a probe, then threads to screw it into something, then there is a plastic piece with a threaded stud coming out of the center. I am assuming that it is a topical sender. I attach a wire to the stud at the end and tightened it down with a nut, but I am not receiving any signal to the gauge. Is there a specific way these thing are supposed to be wired up? Any help would be great. Oh, there are five wires:
Battery
Ground
Back Lighting
Ign On
Sender
'91 XJ, 8" lift, 35x12.5x15 BFGs, 8.8, 4.56
JeepinNH
PostPosted: Tue Jan 09, 2007 7:36 am    Post subject: sending units Reply with quote
Typically 1 wire sending units work by changing resistance to ground which is the case of the unit. The resistance will probably drop as it heats up. You can test with with an Ohm meter and heating the sender under warm water. You should see the resistance change. The guage has 12v on one side and the sender changing the resistance to ground which moves the needle on the guage. Is the sender attached to something that is grounded properly?
Mike
Present: 99 Cherokee
gtouimet
PostPosted: Tue Jan 09, 2007 4:23 pm    Post subject: Reply with quote
Yes I thought it might be a grounding issue, so I attached a wire between the body of the sender and the frame. This seemed to work. However, even when I was driving around town today it did not read above 150. Now I don't know the normal operating temp, but that seemed a little low. So, the two lines coming off the tranny, which one is sending fluid and which is receiving? Is it the forward one or aft one?
