bad brakes
Goto page 1, 2  Next
PostPosted: Tue Jan 09, 2007 4:31 pm    Post subject: bad brakes Reply with quote
So I went wheeling a while back and my brakes have felt a bit funny ever since. When I first push the pedal down its really soft, then if I take my foot off the pedal and press down on the brake again quickly it firms up bit braking still isn't all that great. If I am on a long decent down a mountain road and do the same thing the brakes pump up and then will start to fade pretty quick. I've only had the time to get under and check out the lines and they seem to be fine and i don't see any leaking from the brake calipers.
Are there any checks I can do to narrow down the probable cause? Also I plan on bleeding my brakes and then checking and replacing the master cylinder. I have not blead brakes before but have read the write up on the site that thephantum did. Is there anything special about zjs that I need to know about?
Thanks guys.
PostPosted: Tue Jan 09, 2007 5:56 pm    Post subject: Reply with quote
You're likely looking in the wrong direction by thinking the master cylinder, hard lines, or air in the system.
What kind of wheeling did you do? Any water and/or mud? If yes, then start by disassembling your brakes and cleaning them. Mud and dirty water don't mix well with brakes.
PostPosted: Tue Jan 09, 2007 7:25 pm    Post subject: Reply with quote
Yup, lots of mud and water. In fact the night we went out there was a lot of water, more than usual. It was also pretty cold. Just out of curiosity, if pads or rotors are heated up by a lot of braking force then are put through cold water could that damage the pad by cracking the material?
PostPosted: Tue Jan 09, 2007 7:39 pm    Post subject: Reply with quote
The damage is more likely from dirt and debris contaminating the rotor/pad surface. Disassemble, clean, lubricate, reassemble.
PostPosted: Tue Jan 09, 2007 9:59 pm    Post subject: Reply with quote
mine were the same way, i almost wore the pads down to the shoe in the rear drums, im pretty sure thats your problem as well
goof news its like a 40 buck fix, bad news drums are kinda a pain to do
PostPosted: Wed Jan 10, 2007 8:35 am    Post subject: Reply with quote
Well, the brake pads are only about 6 months old. I had them replaced back in june. I hope and doubt that I have worn them down in only 6 moths. Hopefully sometime this weekend I will have the time to get things taken care of.
PostPosted: Wed Jan 10, 2007 12:33 pm    Post subject: Reply with quote
yea good luck too mine were only 8 months old...mud kills em
PostPosted: Wed Jan 10, 2007 1:11 pm    Post subject: Reply with quote
Wow. What company made your brakes fox? Is there anything out there that is more durable? I don't get out a wheel as much as you unfortunatly. I've been thinking about getting some drilled and slotted rotors but I was waiting till these pads wore out. I was just hoping it would take a little bit longer.
PostPosted: Wed Jan 10, 2007 2:06 pm    Post subject: Reply with quote
Stay out of the mud.
Don't waste your money on the drilled and slotted rotors. Those holes and slots trap dirt and mud more easily and will eat up pads even faster.
PostPosted: Wed Jan 10, 2007 3:39 pm    Post subject: Reply with quote
But I like the mud. But I will stay away from the slotted and drilled rotors.
PostPosted: Wed Jan 10, 2007 3:57 pm    Post subject: Reply with quote
my pads came from napa, ehirner is right the more mud you go in the faster they die, i guess you could pop the drum off and clean the brakes after each outing
PostPosted: Wed Jan 10, 2007 3:58 pm    Post subject: Reply with quote
If you don't want to stay away from mud...then this is about the best you can do. Disassemble and clean every time you're out.
PostPosted: Wed Jan 10, 2007 4:00 pm    Post subject: Reply with quote
or convert to rear discs that would make your brakes last a little bit longer
PostPosted: Wed Jan 10, 2007 4:12 pm    Post subject: Reply with quote
They still pick up dirt and debris regardless of brake type...disc or drum...and should be disassembled and clean each time you go mudding.
PostPosted: Sun Jan 14, 2007 9:34 pm    Post subject: Reply with quote
So what does it mean when the emergency brake light comes on when I am pushing down on the brake and it feels kind of spongy? That kind of freaked me out a little bit. Brakes are a little low but are still ok.
Goto page 1, 2  Next
Page 1 of 2
