Replacing the Hose from Clutch Master Cylinder to Slave...
Maxximmillian
PostPosted: Wed Jan 17, 2007 8:23 pm    Post subject: Replacing the Hose from Clutch Master Cylinder to Slave... Reply with quote
Hello everyone. My 89 Cherokee 4.0 has a leak in the hose that runs from the Clutch master cylinder to the slave cylinder. Has anyone replaced this hose before? How hard is it to replace and are there any special tools that I might need? Thanks a lot.
PostPosted: Thu Jan 25, 2007 5:53 pm    Post subject: Reply with quote
not sure i have an automatic , you would probably want line wrenches , buy a haynes manual or go to your local library and pick one up
Maxximmillian
PostPosted: Sat Jan 27, 2007 12:36 am    Post subject: Reply with quote
Well, FYI for everybody: The job was not that difficult. Just loosen a couple of fittings, fish out the old hose, and reverse for installation of new hose.
