Turn signal
BlueSunday
PostPosted: Thu Jan 18, 2007 8:46 am    Post subject: Turn signal Reply with quote
Alright, the front left turn signal has been giving me problems...
first of all running with my lights on, it doesnt light up at all, however the turn signal light on my dash stays lit
when the turn signal is on, it wont work, though it flashes on the dash
but if i throw on the hazards it lights up but with only about half the brightness that it should be at, so its not the bulb
my rear left signal works
also, im sure its a related problem...the signal doesnt click consistantly, which is kind of funny when its flashing really really fast and then slows riiiiiight down, must look weird to the person behind me
88WOWJ
PostPosted: Sat Jan 20, 2007 3:43 am    Post subject: Turn Signal Reply with quote
A burned out bulb.
With key on and not running .
Turn the signal switch to the side that is not working.
Walk to front or rear of the vehicle and the one that is NOT lighting up is the bulb problem.
1991 Cherokee Limited
