wiring problem.
markherm13
PostPosted: Sat Jan 20, 2007 3:13 pm    Post subject: wiring problem. Reply with quote
i tried to hook my new cd player up so i bought a new wiring harness b/c my previous onwer had cut alot of the old harness and rigged it.
it is a mess back there.
how do you get the plastic top of the back of the steering column where the hazard light button is off?
if i get that off i will be able to take off plastic cover of the dash off and get a better look at the problem.
also i took off my cig light b/c it doesn't work and he had cut the purple wire that origonally been connected to the cig light and cut it and attached it to a black wire w/white stripe that come from where the cd player goes.
also i have 2 plugs from two harnesses for the cd player and i random black solid wire attached to nothing.
if anyone can help
PLEASE HELP!!!
