lift without new springs?
mikeymagic
PostPosted: Wed Jan 24, 2007 12:30 pm    Post subject: lift without new springs? Reply with quote
anyone know of a way too life a 99 cherokee sport 2-4 inches without getting a new shocks/springs? i just replaced mine last month and i want to lift it up a alittle now. can i just bigger leaf springs? or will that not work. all feedback will be much appreciated
PostPosted: Wed Jan 24, 2007 2:09 pm    Post subject: Reply with quote
There are spacer lifts that go up to about 2". That will work for the front. I don't know what's available for the rear because I'm not an XJ guy. I've got coils at all 4 corners on my TJ but our front ends are nearly identical.
You will need new, longer shocks if you lift the vehicle.
PostPosted: Wed Jan 24, 2007 5:35 pm    Post subject: Reply with quote
you could get bigger leaf springs , or blocks Rolling Eyes . if you go for a 2 inch lift get some 3+ shocks . you need shocks even if your jeep sits with your stock ones not holding your axle up because when your jeep articulates you will rip the shocks apart or out of the mount or the mount apart .
rear shocks and springs or blocks and shocks . im not sure what it would do to your drive line angles and i can only remember how to figure it out for larger axles (Over 40 inches long usually not more than 8 deg
Under 40 inches = divide the length by 5 eg 30/5 = 6 deg)
fronts should just need some spacers and probobly shocks ? if you plan on articulating at all
PostPosted: Wed Jan 24, 2007 7:52 pm    Post subject: Reply with quote
If you're looking for 2" of lift without changing springs a coil apcer in the front is the way to go.
As for the rear, there are a couple of options:
Blocks - They fit between the leaf and the axle and provide lift. They will maintain the stock ride, but the problem is they are the leading cause of spring warping. I would not recommend them.
AAL - Add a leaf. Basically it's a leaf that you add to the existing pack which provides lift. The problem with these is that they weill eventually sag, leaving the rear hanging lower than the front. They also have a tendancy to make the ride very harsh.
Extended shackles - A shackle that is 1.75" longer then the stock unit. They will maintain the stock ride. However then do have a tendancy to wear out stock springs a little quicker than normal. Still this is the option I would choose...the lesser of all the evils.
89JeepXJ
PostPosted: Thu Jan 25, 2007 12:58 pm    Post subject: Reply with quote
can someone explain to me how extended shackles lift the vehicle?? sorry im a newb here and i've got my first jeep about 2 wks ago and it has a 4" lift on it but it needs about 2 more inches in the back to sit level front to back...and i was wondering about extended shackles b/c i've heard of it but i never knew how/why it worked or w/e...anybody? thanks
View user's profile Send private message Send e-mail AIM Address MSN Messenger
PostPosted: Thu Jan 25, 2007 4:10 pm    Post subject: Reply with quote
Extended shackles space the springs and axle further away from the from the frame. Because they only work on one end, you only gain lift equal to half the extended length.
For example, 2" longer shackles provide 1" of lift.
89JeepXJ
PostPosted: Thu Jan 25, 2007 5:16 pm    Post subject: Reply with quote
im still not sure i totally understand, maybe i'll have to go underneath my jeep and stare at it haha...where is a good place to buy longer shackles? thanks
PostPosted: Thu Jan 25, 2007 5:22 pm    Post subject: Reply with quote
shackles are at the read of the leaf , you will have to get under it and see them for yourself . is your rear sagging or just not lifted as high as the front? if its sagging your gonna want new leafs not shackles
89JeepXJ
PostPosted: Thu Jan 25, 2007 5:23 pm    Post subject: Reply with quote
ok scratch that last post..haha...i get it now. i appreciate the help..i am still wondering where a good place to get 2" extended rear shackles for an 89 jeep cherokee is....thanks!!
PostPosted: Thu Jan 25, 2007 10:06 pm    Post subject: Reply with quote
any off road parts store should be able to hook you up . the stock shackles on a jeep are anything but beefy so i wouldn't be super concerned . im sure skyjacker or some one similar would have them .
there are licensed parts people to help you , i don't think they will cost you much . there just a hunk of steel with two bushings (put some lithium greese when you install them in the bushing so they don't squeek) .
by the way can you get your leafs off your jeep ? i am guessing its a 89 . when i took mine off i broke two of the bolts in the rear and both of the front ones with a 3/4" ratchet and a pipe , this was after i soaked them in liquid wrench for about a week . and had to cut up the unibody to get the bolts out .
but yours might be different . a good rule of thumb is soak your suspension bolts in WD-40 or nutbuster for a few days if it hasn't been disassembled in a few years or you might end up torching some nuts off .
89JeepXJ
PostPosted: Fri Jan 26, 2007 10:42 am    Post subject: Reply with quote
yeah thats a good idea, i haven't tried it yet so i'll have to see what happens, thanks!
