Sounds at speed
cochran182
PostPosted: Sun Jan 28, 2007 7:01 pm    Post subject: Sounds at speed Reply with quote
I am getting some sounds from what I think is the front right. I am assuming it is the bearing. At 40-45 I start to hear it and it goes away at about 50. Then it sounds even louder starting at 60 to 75 and then it goes away again. It is like a humming or whirring sound. I get just a little vibration, not hardly even noticeable.
What do you guys think? Bearing in the wheel hub assy? I would like to be fairly certain... the hub assemblies seem pretty costly at $150 each. It there a way to tell for sure?
also, what do you guys think about the NAPA Hub assemblies?
PostPosted: Sun Jan 28, 2007 8:17 pm    Post subject: Re: Sounds at speed Reply with quote
Jack of each side, tug/push at 12 and 6, then again at 3 and 9. There should be no play in the unitbearings, balljoints, and/or tie rod ends. Spin the hub to check for smooth rotation.
