Shackles And Add A Leaf
jeepromper
PostPosted: Mon Jan 29, 2007 6:56 pm    Post subject: Shackles And Add A Leaf Reply with quote
I have a 86 Cherokee Laredo 2.8 v6 and I was wondering If I Put A 2 inch lift With shackles and 1.5 lift with add a leaf in the rear Would that work and Would I have to extend anything to do so.
Thanks
PostPosted: Mon Jan 29, 2007 8:27 pm    Post subject: Reply with quote
How do you plan on lifting the front with shackles and add-a-leafs?
PostPosted: Wed Jan 31, 2007 7:23 pm    Post subject: Reply with quote
you probably want some +3 shocks and maybe a brake line drop brakcet or a longer brake line .
what do you plan for the front , a +3" lift usually requires some alignment tweaking eg. t-case drop or double cardian or wedges .
with the ad a leaf are your leafs already sagging because if they are your +3" isn't gonna last very long and it will ride poorly .
personally not a big fan of add a leafs , i know leafs out of a older suburban slip right in and they give about a +3 lift . i would look into something like that or just some +3 leafs .
jeepromper
PostPosted: Thu Feb 01, 2007 6:36 pm    Post subject: Reply with quote
Just A Standard Sus lift for the front Coils shocks etc.
Yeah My leafs are sagging.
My leafs are shifting already too.
Thanks for the help
