Knock Knock,Whos there?
PostPosted: Fri Feb 02, 2007 5:10 am    Post subject: Knock Knock,Whos there? Reply with quote
Well I had a bad feeling that the wife blew up the 4.0 liter motor in my 93 JGC yesterday when she got home all I could here was a really bad knocking sound coming from the front of the engine .It sounded like the wrist pin or crank bearing was gone,PS I have been a mechanic for over 15 years and have seen lots of bad motors and heard lots of knocking sounds,But this was bad and was ready to order anouther engine and thought I should really check it out.As a result with my stethiscope could only here the knock in the front very 1st cyland bad I might add.Well I removed the front drive belt in the thought that I have seen this before with a lot of fords that the harmonic or vibration damper was a culprit to making a pile of noise but this was a bad knock.Well after removing the belt and restarted the jeep all was perfect YAHOO.After looking and finding out that the problem was nothing more than the idler wheel that the belt runs on was shot the bearing hadlet go inside.Well called the dealer and they wanted $75.00 for the whole pully and they tell me they dont just sell the bearing so I bought just a bearing from my autoparts store for $8.00 replaced and problem solved.WELL moral to this story is dont give up so soon and make a bad call I know that this has fooled many people if you here a bad knock in the front of the engine it will come with no sign PLEASE remove belt and check again could be the same problem HOPE THIS IS OF SOME HELP TO SOMONE.
1967 chev shortbox stepside
1988 gmc 4x4
1989 gmc 2x4
1993 jeep grand cherokee
PostPosted: Sun Feb 04, 2007 9:02 pm    Post subject: Reply with quote
great post man!!!! thanks a bunch! i hope his saves some heads some loot!
