| Author |
Message |
Orangeamc13 Moderator
Joined: 20 Feb 2006 Location: East Springfield, Massachusetts - U.S.A.
Posted: Mon Feb 05, 2007 8:44 am Post subject: New Super Coils |
WARNING DO NOT TRY THIS AT HOME OR ANYWHERE ELSE!!! NO MATTER WHAT YOUR BUDDY TELLS YOU!!!
I found these while surfing the other day and had to share them. I got a good laugh and I am sure others will too!!! _________________ 83 CJ7 4.2, 88 XJ 4.0, 94 ZJ 5.2, 99 XJ 4.0
UNDERGROUND JEEPS
| Back to top |
5.9 andy Member
Posted: Sun Feb 25, 2007 3:45 pm Post subject: |
| WTF!!!!!!! who is nuts enough 2 try that? |
| Back to top |
| Back to top |
Code3TJ Hacker
Posted: Sun Feb 25, 2007 6:26 pm Post subject: |
Dear God!  _________________ Nothing to see here. |
| Back to top |
Drake69 Member
Posted: Sun Feb 25, 2007 10:08 pm Post subject: |
The dual spring one's got Darwin written all over it. He ought to stand next to the wheelwell while his buddy attempts to flex and compress those springs. At least we won't have to worry about him reproducing if he does.
| Back to top |
5.9 andy Member
Posted: Mon Feb 26, 2007 6:09 pm Post subject: |
| i agree |
| Back to top |
Brad The Best Member
Posted: Fri Mar 02, 2007 7:14 pm Post subject: |
even if those spring's left your vehicle at stock height they would be scary , but they look like they would double your shock height .
i feel so much better about my jeep after seeing those |
| Back to top |
fishjrl Member
Posted: Sun Oct 28, 2007 6:47 pm Post subject: |
aaaaaaaahhhhhhhhhhh
run away
some of those made me laugh so hard i cried, shit my pants, and threw up all at the same time.
spent 3 hours lookin through those pages |
| Back to top |
Posted: Sun Oct 28, 2007 8:01 pm Post subject: |
UNDERGROUND JEEPS
| Back to top |
hutchman Captain Kirk
Posted: Sun Oct 28, 2007 8:46 pm Post subject: |
Some real engineering on this one:
I really like the step. It should really help the vertically challenged! |
| Back to top |
lakeland713xj Member
Joined: 04 May 2007 Location: middle of no where florida
Posted: Mon Oct 29, 2007 10:29 am Post subject: |
alright you think thats funny a kid that went to my high school has a ranger that is SAS with no lift and took another frame and welded 15 inch suports between it for a 15" body lift then he got some dana 44 8 lugs and instead of moving he spring perches to fit the leaf distance he took some 4x4 steel .250 wall tubing and weledit it to the top of the axle tube on tope the spring perch so they would fit where ever he needed them..but yet he put in a create chevy TBI 350 on a turbo 400 tranny with a NP-205you can see his engine steering box and all that throw the "gap" a full sized man could squuezr thru the bed...oh and for a light bar he took some regular head lamps and bolted them to his grill... _________________ Jeep cherokee 98 4.0
6.5" rough county
33x12.50 toyo mts |
| Back to top |
Posted: Mon Oct 29, 2007 3:23 pm Post subject: |
| lakeland713xj wrote: | | alright you think thats funny a kid that went to my high school has a ranger that is SAS with no lift and took another frame and welded 15 inch suports between it for a 15" body lift then he got some dana 44 8 lugs and instead of moving he spring perches to fit the leaf distance he took some 4x4 steel .250 wall tubing and weledit it to the top of the axle tube on tope the spring perch so they would fit where ever he needed them..but yet he put in a create chevy TBI 350 on a turbo 400 tranny with a NP-205you can see his engine steering box and all that throw the "gap" a full sized man could squuezr thru the bed...oh and for a light bar he took some regular head lamps and bolted them to his grill... |
Where's the pics? _________________ 83 CJ7 4.2, 88 XJ 4.0, 94 ZJ 5.2, 99 XJ 4.0
UNDERGROUND JEEPS
| Back to top |
Posted: Tue Oct 30, 2007 3:51 am Post subject: |
i graduated already but ill try to get a pic he works at the lock car wash _________________ Jeep cherokee 98 4.0
6.5" rough county
33x12.50 toyo mts |
| Back to top |
viper24242 Member
Posted: Tue Oct 30, 2007 10:09 am Post subject: |
This is not really jeep related but back in the day when I was in high school I knew a guy who wanted hydrolics in his busted up lincoln towncar so bad that instead of doing it the right way (which on a towncar there is no right way) he took all the bolts off the frame and body except two in the middle of the car. That way whenever he hit the brakes the body would just rock back and forth on the frame. Now I thought the guy was stupid but if you factor in getting in a rearended or head on collision scenario at even low speeds, I would imagine that the body would just shear off the two bolts holding onto the frame and take half his body with it. _________________ '94 Grand 5.2L
Rusty's Tie Rod Conversion |
| Back to top |
5.9 andy Member
Posted: Mon Dec 10, 2007 5:34 pm Post subject: |
| viper24242 wrote: | | This is not really jeep related but back in the day when I was in high school I knew a guy who wanted hydrolics in his busted up lincoln towncar so bad that instead of doing it the right way (which on a towncar there is no right way) he took all the bolts off the frame and body except two in the middle of the car. That way whenever he hit the brakes the body would just rock back and forth on the frame. Now I thought the guy was stupid but if you factor in getting in a rearended or head on collision scenario at even low speeds, I would imagine that the body would just shear off the two bolts holding onto the frame and take half his body with it. |
it will eventualy. |
| Back to top |
