Leaf Spring Removal Problem
kawkx500
PostPosted: Wed Mar 18, 2009 5:56 pm    Post subject: Leaf Spring Removal Problem Reply with quote
Any ideas on how to remove the bolt from the front bushing of the right side leaf spring of a 93 cherokee. The sleeve is spinning inside the rubber bushing and i cant get the bolt out. I dont know why they made it the way they did in the fronts because the darn things dont have a nut on the inside its just a bolt that treads into the frame. I was thinking about heating it up with a torch and trying to get it out that way. Input from anyone would be greatly appreciated. Im not going to be using the leaf springs that are coming off so i dont really care if they get ruined in any way. Thanks.
