Weird start up noise
94BGCherokee
PostPosted: Sun Feb 11, 2007 12:34 am    Post subject: Weird start up noise Reply with quote
94 cherokee 168000 miles. When i start the car whent its astro cold, like 20 degrees or below, I get this loud wiining sound from under the hood, almost sounds like a whirring. It is intermittent when its cold when i let it warm up, i can hear it inside my house. Im thiniking its p/s considering the water pump is new, the alternator charge is fine, and the a\c sounds great(stethescope). and since its hard to turn the wheel when you first start it, thats what makes me think thats what it is. Not like its getting worse just an annoying sound. Any Ideas if it is P/S, just wait till it goes out, is there any maintainence I can do on it? Idler pulley has been replaced as well. Belt is new, its not slipping ive checked that. P/s it not leaking and its full, so i have no idea. Input and help is greatly appreciated, thanks for looking.
JeepinNH
PostPosted: Sun Feb 11, 2007 11:16 am    Post subject: noise Reply with quote
Sounds like the p/s pump to me. I had an 86 that made the same noise. Sometimes the fluid would spray out the cap. I changed pretty much everything in the p/s line and it still happened so I just ignored it. Maybe I should have stayed away from rebuilds.
Mike
Present: 99 Cherokee
PostPosted: Sun Feb 11, 2007 1:23 pm    Post subject: Reply with quote
Do you have enough tension on your serpentine belt?
PostPosted: Sun Feb 11, 2007 4:07 pm    Post subject: Reply with quote
mine does that as well its just the serpentine belt ( it's adjusted properly i used a fancy tool for it ) im sure it would go away with a new belt in my case. i have just learned to live with it .
check your belt out first . condition and how tight it is
