Under hood oil soaked, help.
94BGCherokee
PostPosted: Wed Feb 14, 2007 8:41 pm    Post subject: Under hood oil soaked, help. Reply with quote
I was driving my cherokee the other day and I was on the highway cruising in O/D, I went to get on it and took her to about 4 grand, and all of a sudden smoke just start pouring out coming inside the car, out the back everywhere, oil pressure is fine so im like what the hell, the car wasnt running bad so i pulled over. I check underneath the hood and its tranny fluid, checked the fluid, level was fine, maybe a little full, color was perfect, fluid was not smoked. Only thing I can think of if it was over full there was some type of pressure release valve.
PostPosted: Thu Feb 15, 2007 5:07 pm    Post subject: Reply with quote
there is an overflow / vent that i believe will puke oil onto your hood . don't overfill an automatic transmission ever
94BGCherokee
PostPosted: Thu Feb 15, 2007 5:10 pm    Post subject: Reply with quote
What happens when you do?? DOes it damage it?
PostPosted: Thu Feb 15, 2007 7:22 pm    Post subject: Reply with quote
yes it can damage the transmission . there are several things that can happen . all you really need to know is its not good . don't do it again and you should be alright.
how far over was it ? did you check it properly ? vehicle on in neutral hot
