seat from grand cherokee to my cherokee
koltonv
PostPosted: Fri Feb 16, 2007 1:06 pm    Post subject: seat from grand cherokee to my cherokee Reply with quote
I have a 93 cherokee, the seats are trashed, does anyone know if the seats from a grand cherokee will fit?
PostPosted: Wed Feb 21, 2007 8:23 pm    Post subject: Reply with quote
not a clue , the actual mounts probably wont but you can take the seat off the mount and put it on your's . compare before you purchase , i wish i could be more help
rix
PostPosted: Wed Apr 11, 2007 2:26 am    Post subject: Reply with quote
yes they will. the front seats are easy, just switch the bottom track bracket so you end up with the cherokee brackets on the grand cherokee seats. there are no holes to drill it just bolts on. the back seats are a bit trickier. from the old rear seat you need to take off the side brackets that has the rod that goes into the rocker panel, the grand cherokee rear seat is usually a 60/40 split seat. fit the bottom outside edge of the new seats with the side bracket taken off the old seats.it takes a bit of imagination but it can be done. you can attach these with a pop rivet gun. now you have them secured in the original side holes. if you take the brackets off the bottom of the grand cherokee seat and reinstall one of the brackets on each seat, closest to the center of the seats, backwards it will prevent the seat from sliding forward in the middle. the back of the seat is fairly easy to line up and drill holes for the end and middle brackets of the grand cherokee seat. make sure that the seats you buy have that center bracket for back of the rear seat or the seats won't work.
you will lose some room in the back and the front seats will be a tad bit higher but it is worth the effort. i bought my seats on ebay for $30 and a 50 mile drive to pick them up. they were in primo shape. i also sold my old ones for $40 on ebay. so it worked out well
dancerman
PostPosted: Wed Apr 11, 2007 2:36 am    Post subject: Reply with quote
What year JGC are we talking about? I have a '99 Sport and have often thought of swapping to JGC front seats.
rix
PostPosted: Wed Apr 11, 2007 6:11 am    Post subject: Reply with quote
Mine is 95 sport and the seats were from a 99 JGC
