Doors wont lock...
windsurf
PostPosted: Thu Mar 15, 2007 2:03 pm    Post subject: Doors wont lock... Reply with quote
My Grand cherokee has been of the road for about a year So last week I hooked up the battery again. everything works well except the central locking system. All the doors will unluck using the remote, but when locking again it's only the drivers door that locks. There is no noise or anything from the other 4 doors. Does anyone have a solution to this (electrical) problem?? Thanks!
cajzmere
PostPosted: Thu Mar 15, 2007 3:58 pm    Post subject: Reply with quote
Check the wires going from the driver's door into the body inside the black boot thingy. Check them one by one. They have an issue in this spot alot. Use the "search" function in this forum, there have been lots of posts.
windsurf
PostPosted: Sat Mar 17, 2007 12:53 pm    Post subject: Reply with quote
Have tried to check the wires, and nothing... also same when problem using the switch on the passenger side... was told by a fellow that these locks are controlled by the computer, but taking of the battery does not fix it.. any suggestions would be very well recieved!!!
windsurf
PostPosted: Tue Mar 27, 2007 2:55 am    Post subject: Located problem!! Reply with quote
Finally after downloading a service manual and learning a few things about the wiring of the car, I located the problem to be the front passenger door module (PDM) that has a malfunction. However they are very pricy. so will try to try to change the burned off relay on the the unit myself. Once and a while its just about getting a bit dirty....
