89 cherokee power window regulator ?
carpetrugger
PostPosted: Sat Mar 17, 2007 8:19 am    Post subject: 89 cherokee power window regulator ? Reply with quote
I can't fiqure out how to get the regulator and motor out of the door. I have drilled out the three rivits holding the motor to the door and now have the motor loose but don't know what to do next. Is there a way to get the window down as it is up now? thanx
PostPosted: Sun Mar 18, 2007 6:57 pm    Post subject: Reply with quote
you also have to take the rivets that hold the track to the door then you can pivot the hole assembly back and bring the window down and remove the torx holding it in place or role down the window . i just did this a month ago it takes a little patience
