ZJ lights project
589Outlaw
PostPosted: Wed Mar 21, 2007 11:48 pm    Post subject: Reply with quote
No problem. If you need help finding anything like that just let me know. I looked around quite a bit before I bought all my stuff.
97 ZJ Laredo - 4.0 with cold air intake, Magnaflow muffler/cat, clear corner and tails, custom tire rack
589Outlaw
PostPosted: Wed Mar 21, 2007 11:49 pm    Post subject: Reply with quote
By the way Viper....how do you like that Flowmaster 50? Would you recommend it?
PostPosted: Thu Mar 22, 2007 7:39 am    Post subject: Reply with quote
I would definantly recomend it. With that and a new intake it really opened the engine up. And I love passing wanna be street racers with those coffee can exhausts, makes me feel like more of a man rofl
589Outlaw
PostPosted: Thu Mar 22, 2007 10:54 am    Post subject: Reply with quote
Cool... I will start looking for one.
PostPosted: Thu Mar 22, 2007 1:55 pm    Post subject: Reply with quote
How are you mounting your tire on your roof rack? Did you get a tire carrier or did you rig something up yourself?
589Outlaw
PostPosted: Thu Mar 22, 2007 6:53 pm    Post subject: Reply with quote
I made it myself. I took two 3-foot long pieces of square steel tubing and then welded a piece of flat steel across them like an H. Drilled a hole in the middle of the flat piece and welded a 1/2 inch bolt through it. I drilled holes in the factory roof rack and bolted the frame to it. Then threw the tire on and used the plastic piece that was in the center of the factory spare with a wingnut holding it on. The strap is just for extra measure, but that is about it. Looking back, I should have put one more flat piece across the center for a little more support. But it doesn't budge the way I have it, so I am leaving it alone for now.
PostPosted: Thu Mar 22, 2007 7:16 pm    Post subject: Reply with quote
from the looks of it you could also stick the high lift up there
haha rename this thread to zj mods, and outlaw i have the 40 series muffler but im running the I6, it sounds pretty nasty, ive gotten quite a few compliments
PostPosted: Thu Mar 22, 2007 9:02 pm    Post subject: Reply with quote
Yeah, I wish I had a welder so I could make stuff like that. Of course I would probably end up burning my house down.
589Outlaw
PostPosted: Fri Mar 23, 2007 7:30 am    Post subject: Reply with quote
I always use mine with adult supervision. LOL J/K
I didn't notice that Viper had the V8. Thanks for pointing that out. I also have the I6 in mine 1fox2go. Do you know the difference between the Flowmaster 40 and 50 series? Or would it matter which one I went with? I am open to suggestions. It has been 8 years since I have put custom exhaust on any of my trucks so I am a little out of touch with it.
PostPosted: Fri Mar 23, 2007 8:14 am    Post subject: Reply with quote
the 50 series is a little quieter than the 40 series, i know when i pull a hill at 2k rpm it sounds really sweet
PostPosted: Fri Mar 23, 2007 8:19 am    Post subject: Reply with quote
I think my friend has a 40 on his xj. It sounds ok but I am probably spoiled by the sound of my v8. I can still usually hear him coming down the street before I can see him. No matter what you go with its going to sound so much better than stock.
589Outlaw
PostPosted: Fri Mar 23, 2007 9:37 am    Post subject: Reply with quote
Ok, thanks for the info guys.
Here are a couple more pics of how the tire is attached to the carrier.
Topside
Underneath
PostPosted: Fri Mar 23, 2007 3:37 pm    Post subject: Reply with quote
Does your spare have an xj/tj rim?
589Outlaw
PostPosted: Sat Mar 24, 2007 5:45 am    Post subject: Reply with quote
I actually don't know what it came off of, but it fit perfectly. My brother gave it to me after someone gave it to him. It obviously won't match if I have to use it though.
PostPosted: Sat Mar 24, 2007 9:47 am    Post subject: Reply with quote
As long as it gets you off the trail, thats what counts.
