Will This Fit????
fire jeep
PostPosted: Thu Mar 22, 2007 6:49 am    Post subject: Will This Fit???? Reply with quote
Im at a loss right now guys. I have a 6cly motor out of a 1966 Ford Bronco, its 170 Cubic inch. Will this bolt up to my trans. in my 1981 CJ 7? Any help or ideas on this would be great. Thanks
Shocked
PostPosted: Thu Mar 22, 2007 8:41 am    Post subject: Reply with quote
What transmission do you currently have? If you have the Ford tranny, it would probably make it a whole lot easier to swap it also because some of the 81 transmissions weren't the best. Also, not sure where you are, but you might want to check to see if there are any smog laws that require the engine to be the same year or newer than the vehicle it's going into.
fire jeep
PostPosted: Thu Mar 22, 2007 9:08 am    Post subject: Reply with quote
What ever stock is, is the transmission that is in my jeep right now. Im not sure what its is and i am having a hard time finding this info. I have checked the state laws and im good. Good thinking though and thanks for that heads up.
PostPosted: Thu Mar 22, 2007 9:35 am    Post subject: Reply with quote
http://www.novak-adapt.com/knowledge/fsb_swap_cj5_cj7_80-86.htm
This is about V8 swaps, but there's lots of good info on this page. If you go about 1/4 the way down, there's info on the transmissions.
fire jeep
PostPosted: Thu Mar 22, 2007 8:24 pm    Post subject: Reply with quote
Thanks for all your help
