| Author |
Message |
Destefano027 Member
Posted: Mon Mar 19, 2007 3:00 pm Post subject: Will Someone Help Me |
| i have a 78 cj 7 that does not more forward just backward it feels like it want to move but it doest i no it is not the trany because i just had it rebuilt but all at the same time i put a dana 44 rear and a 30 front i also changed the transfer case could it be one of them what could be wrong why dosent my jeep move |
| Back to top |
ehirner Moderator
Posted: Mon Mar 19, 2007 5:54 pm Post subject: |
Does it roll forward if you put it in neutral and push it? _________________ 04 Unlimited |
| Back to top |
Destefano027 Member
Posted: Tue Mar 20, 2007 4:19 am Post subject: |
| yes |
| Back to top |
ehirner Moderator
Posted: Wed Mar 21, 2007 3:22 pm Post subject: |
I would think that rules out the axles, differentials, brakes frozen solid, and t-case. Perhaps something tranny or engine related. _________________ 04 Unlimited |
| Back to top |
Destefano027 Member
Posted: Thu Mar 22, 2007 3:10 am Post subject: |
| i realy dont think it is the motor or the trany they were just rebuilt. i was thinking it would be in something i changed because it worked before i changed it like the axles or transfer case because they were both used |
| Back to top |
Code3TJ Hacker
Posted: Thu Mar 22, 2007 8:42 am Post subject: |
Have you (carefully) jacked it up to see which tires you can get to turn under power? _________________ Nothing to see here. |
| Back to top |
Destefano027 Member
Posted: Thu Mar 22, 2007 9:11 am Post subject: |
| yes all the tires turn in the air but on the groung they dont turn but it does go in reverse |
| Back to top |
Code3TJ Hacker
Posted: Thu Mar 22, 2007 9:49 am Post subject: |
| Destefano027 wrote: | | yes all the tires turn in the air but on the groung they dont turn but it does go in reverse |
They turn, but is this under power or just turning them by hand? What does it do if you put it into 4H? Do the driveshafts turn? _________________ Nothing to see here. |
| Back to top |
Destefano027 Member
Posted: Thu Mar 22, 2007 11:59 am Post subject: |
| everything works properly all like it should the tranny shifts like it should and the tires spin when you hit the gas i was thinking that maby it was in the rear end the pinon gear or ring gear something like that but im not sure what to check for |
| Back to top |
Orangeamc13 Got Rev Limiter?
Joined: 20 Feb 2006 Location: East Springfield, Massachusetts - U.S.A.
Posted: Thu Mar 22, 2007 2:04 pm Post subject: |
Are the differential gears the same size? _________________
| Back to top |
Destefano027 Member
Posted: Thu Mar 22, 2007 4:39 pm Post subject: |
| yea they are 3 73 |
| Back to top |
Brad The Best Member
Posted: Sat Mar 24, 2007 10:14 pm Post subject: |
| Destefano027 wrote: | | i realy dont think it is the motor or the trany they were just rebuilt. i was thinking it would be in something i changed because it worked before i changed it like the axles or transfer case because they were both used |
just because they were rebuilt doesn't mean that some one didn't mess up.
i would guess your transmission is the problem .
you could take the diff covers off and then spin them and watch what happens check backlash etc inspect for wear or misalignment , if you think tis the diffs that is . |
| Back to top |
Destefano027 Member
Posted: Sun Mar 25, 2007 5:40 pm Post subject: |
| it was the rear end the pinon was all tore up it only had a couple of teeth left on it . what could of caused this |
| Back to top |
Posted: Sun Mar 25, 2007 7:41 pm Post subject: |
burn out's , improper backlash setting , backing into something really hard , pinion aligned wrong
basically misalignment and abuse or defective , glad to hear you found out what was wrong |
| Back to top |
Destefano027 Member
Posted: Tue Mar 27, 2007 3:13 am Post subject: |
| thanks for all the help |
| Back to top |
