stuffin tires
Goto page 1, 2  Next
topsideroyal
PostPosted: Wed Apr 04, 2007 7:27 pm    Post subject: stuffin tires Reply with quote
How hard do you guys think it will be to stuff 33" tires under my 2000 Grand Cherokee with a 3.5" lift
PostPosted: Wed Apr 04, 2007 9:22 pm    Post subject: Reply with quote
you will need to trim the fenders so you dont rub when you hit bumps
if all you want to do is ride on the road with 33s you wont have to trim much, if you plan to go off road you will need to trim a good bit
PostPosted: Thu Apr 05, 2007 6:52 am    Post subject: Reply with quote
Get out the sawzall!!!
topsideroyal
PostPosted: Fri Apr 06, 2007 10:27 am    Post subject: Reply with quote
hell yeah, i love the sawzall.
PostPosted: Sun Apr 08, 2007 2:00 pm    Post subject: Reply with quote
I bet I could fit 33's on a stock WJ... rofl rofl
topsideroyal
PostPosted: Mon Apr 09, 2007 5:31 pm    Post subject: Reply with quote
yeah how would you go about doin that, keep in mind im still tryin not to trim to much seeing how it is still my daily driver.
5.9 andy
PostPosted: Tue Apr 10, 2007 10:39 am    Post subject: Reply with quote
if i was gona stuff 33's with a 3.5" i would chop my fenders up to the point where they flare out on an angle before it drops back down.
I dont know what i would do about the rear because the door is so close to the well, i think swampy said some thing about using adjustible control arms to push the axle back.
im shure its possible and im shure it can work but it will requre metal cutting and im not shure if u wana do that to ur DD.
PostPosted: Tue Apr 10, 2007 12:14 pm    Post subject: Reply with quote
if you dont want to trim much then i would find a 5 inch kit
if you found a 4 inch kit you could get by without that much trimming, since you will be on road all the time you wont have the worry of the suspension flexing and rubbing the fenders
5.9 andy
PostPosted: Tue Apr 10, 2007 8:43 pm    Post subject: Reply with quote
if its just gona be a street queen then u wont have 2 do insane cutting but threr will still be some.
topsideroyal
PostPosted: Wed Apr 11, 2007 10:17 am    Post subject: Reply with quote
i do plan i takin it off road, what would be the point of liftin it if i didnt. but its not goin to be anything insane just tryin to have some fun over the weekend with a small budget.
PostPosted: Wed Apr 11, 2007 10:59 am    Post subject: Reply with quote
AWSOME! at least you will take it off road, well then what i would do is get a 5 inch lift if your budget allows, if not go with 3.5 and run 32s, if you have 16 inch wheels run a 265-75. if you get the 5 inch kit you can run 285-75s with minor trimming
PostPosted: Wed Apr 11, 2007 11:11 am    Post subject: Reply with quote
I would just like to point out the fact that depending on what motor you have you might have to regear the differentials. Since it is your daily driver gas milage will suffer if you run 33's without regearing.
5.9 andy
PostPosted: Wed Apr 11, 2007 6:06 pm    Post subject: Reply with quote
yea thats a good point, regearing will be importiant with 33's no matter what engine u run.
PostPosted: Wed Apr 11, 2007 9:09 pm    Post subject: Reply with quote
I guess it depends on what you require in a daily driver.. I used mine as a daily driver for a while.. Mr. Green
But I am much more comfortable in the Montero..
(by the way.. I was able to fit 32's on my Monty with no lift.... Mr. Green )
topsideroyal
PostPosted: Thu Apr 12, 2007 10:38 am    Post subject: Reply with quote
the reason i am putting 33 on is because my buddy sank his truck and didnt want to mess around tryin to fix it so he pussed out and bought a little s-10. so im taking the 33 of his hands for 200 bucks there is only about 1500 miles on them, good deal. now what were u guys sayin about regearing? what gear would you guys sugjest? if i dont regear it i will probly mess up my trans after awhile right.
Goto page 1, 2  Next
Page 1 of 2
