Anybody know where??
rix
PostPosted: Tue Apr 10, 2007 5:15 pm    Post subject: Anybody know where?? Reply with quote
I have a 1995 cherokee sport.Anybody know where the rear wiper washer fluid resevior is located?
PostPosted: Tue Apr 10, 2007 5:28 pm    Post subject: Reply with quote
The front and back washers run off the same reservoir. There are two seperate pumps.
rix
PostPosted: Tue Apr 10, 2007 6:35 pm    Post subject: Reply with quote
I am getting a low washer light but the washer fluid tank is full. what could be the problem? Also I do not seem to get any fluid to the rear wiper.
PostPosted: Tue Apr 10, 2007 6:45 pm    Post subject: Reply with quote
The fluid level sensor may be stuck our shot. The pump is probably dead. Can you hear anything when you try the rear washers? I'm not sure where the washer tank is located on the 95's. Can you see the tank or is it in the fender?
rix
PostPosted: Wed Apr 11, 2007 1:45 am    Post subject: Reply with quote
yes I can see the tank clearly right behind the radiator tank. I think it worked before I took the hose off to paint it.
JeepinNH
PostPosted: Wed Apr 11, 2007 5:25 am    Post subject: Reply with quote
You should see 2 pump motors under the tank. The one for the rear window usually dies first from lack of use. My old XJ would put the light on when 1/2 full or lower, check the switch. You should see the 2 wires for it near the top of the tank.
Mike
Present: 99 Cherokee
PostPosted: Wed Apr 11, 2007 6:42 am    Post subject: Reply with quote
Have someone turn on the front and then rear washers while you listen at the reservoir. If you put you hand on the pumps you can pinpoint the bad one. Then you can tell which is pump needs to be replaced.
