Possibe Chrysler Rear Diff Issue, Please Help!
mrench01
PostPosted: Wed Apr 11, 2007 3:02 pm    Post subject: Possibe Chrysler Rear Diff Issue, Please Help! Reply with quote
I have a 1995 Cherokee Sport 4x4 with 4.0L, Auto, and the Chrysler rear Diff (not Dana).
I have had the rear wheel bearing replaced because they were worn out. However I hear this clunk sound when I "let off" the gas at highway speeds and when I accelerate from a stop.
Also I hear gear whine from the back when I am in a long right-hand curve in the road, but I don't hear anything when I am driving straight or in a left-hand curve.
I have read that this might be the Pinion or Diff Carrier bearings or the crush sleve. What do you guys think? Also what does something like this cost to have repaired.
Thanks!
~Mike R~
PostPosted: Wed Apr 11, 2007 6:06 pm    Post subject: Reply with quote
the only way to find out is to pop the diff cover . if the bearings have failed or are failing they will probably take out most of the differential if not fixed .
to just get the bearings replaced will probably be at least a several 100$ if only the bearings are worn . im not sure on an exact price because i do stuff like that myself but just paying for the bearings is probably 100$.
i am not sure if that is your problem the only way to check is to visually inspect it .
