streching out soft top
BIGDANE36
PostPosted: Thu Aug 23, 2007 7:52 pm    Post subject: streching out soft top Reply with quote
i have a 94 wrangler that came with a soft top but it has shrunk and now does fit all the way around is there any way i can strech it out and use it again?
PostPosted: Fri Aug 24, 2007 7:59 am    Post subject: Reply with quote
The only thing I can think of, is to lay it flat in the sun for a few hours. That should make it more stretchy. It should go on pretty easy once it's warmed up. Take off all the windows before trying to get it back on, it will be a lot easier!
Nmurphy13j
PostPosted: Sat Aug 25, 2007 3:12 pm    Post subject: Reply with quote
a trick i ussualy use is just put all the little slider things in, but not the bars all the way up then just push them into place and it should strech all the way taunt
JOHNB279
PostPosted: Sat Sep 01, 2007 2:37 pm    Post subject: Reply with quote
PUT IT ON THE BEST YOU CAN,LET IT SIT IN THE SUN.....OR GO NAKED
