new combo review
Post new topic   Reply to topic     Forum Index -> Body & Paint
oldcarguy
PostPosted: Tue Feb 28, 2006 9:47 am    Post subject: new combo review Reply with quote
proteins; the building blocks of the body; as well as the week reduces the risk of heart what are you waiting for? Start managing your weight today
If only Midway didn't make that stupid wrestling game then they would have saved a small expense there We should be thankful that only Midway's US organisation has been hit and not their internationa
not as specific for gender and age as the RDAs and therefore one quantity some of the more dubious chemicals floor muscles. If you plan to have a baby
lines harbouring a defective viral replicase, ities to many bacterial and protozoan 120 Vaccination, Genetic Substitution of a defect gene
Billy's89XJ
PostPosted: Tue Feb 28, 2006 4:44 pm    Post subject: Re: xj door hinges ?? Reply with quote
oldcarguy wrote:
What's the deal with the door hinges (welds) snapping off the body ?Seen a couple of parts cherokees and all ahd similar problems. Anyone ever weld their own back on and waht were the results ?? I'm kind of worried about heat damage (weakening) any way to swap to bolt up hinges??
I've done a few myself. EXTREME- I always like to cut the old one off, if it hasn't yanked it's self off 100% rofl Go behind it with a 1/4 thick plate bigger than the opening and weld that puppy up. Grind smooth and re-weld the hinge on. MILD ( simple weld break )- I have done a couple that I grinded the old welds off and re welded, worked great. Just don't weld on it all at once or the heat can warp it. Hope this helps Mr. Green
oldcarguy
PostPosted: Wed Mar 01, 2006 10:34 am    Post subject: door hinges Reply with quote
Thanks for the info, about what i had figured. know anything about the repair kits jeep sells ( supposedly ) for this problem? They claim a no weld remedy, under service bulletin 23-017-02, but so far all I'v found are references to this bulletin and not the actial bulletin itself w/ the instructions for repair.
Are there any other common problems to older cherokees i should be on the lookout for? My first jeep. thanks for the help......
emr454
PostPosted: Thu Apr 19, 2007 7:57 pm    Post subject: Reply with quote
Yea, I've had to weld mine twice in 2 years. Both times I had to remove the door and take the hinge off completely and re-weld it back on. Big pain in the ass IMO. If it happens again, I'm just gonna lock the door and get in from the passengers side!
Eric
PostPosted: Fri Apr 20, 2007 7:23 am    Post subject: Reply with quote
I had to weld mine too. I just ground the old weld off and rewelded. I also welded the part of the hinge facing the door opening, there is no factory weld there. Hoping it adds some strength. So far it's been fine.
Emr you could always weld the door seam and go "Dukes Of Hazzard" style!!!
Post new topic   Reply to topic     Forum Index -> Body & Paint All times are GMT - 8 Hours
