4x4 swap
brent bartman
PostPosted: Wed Apr 25, 2007 6:44 pm    Post subject: 4x4 swap Reply with quote
i jsut bought a 99 XJ cherokee 2wd 4 dr....its clean and low miles got it for 3700.....well i want to do a suspension and front axle swap..i know it pretty much bolt on but what will i have to do with my t case shifter routing and all that mess has anyone done this and can they give some pointerS???
92 XJ
4.0L
pace setter exhaust
AFE cold air
jet chips TBS
4 inch rustys spring pack
32 TSL (more like street slicks)
PostPosted: Wed Apr 25, 2007 9:18 pm    Post subject: Reply with quote
shifter mounting is absolutely the easiest part of a project like that , if there isn't a hole with just a plate over it then you will simply have to cut one . look for outlines or markings of were it should be and cut there ( car company's don't like to make a bunch of different body's they usually just put panels over the holes or don't punch them all the way .
PostPosted: Thu Apr 26, 2007 9:13 am    Post subject: Reply with quote
This may help some.
http://www.jeephorizons.com/phpbb/viewtopic.php?t=11231&highlight=
brent bartman
PostPosted: Thu Apr 26, 2007 5:50 pm    Post subject: Reply with quote
i dont have to divorce mount the t case it will bolt right up???
92 XJ
4.0L
pace setter exhaust
AFE cold air
jet chips TBS
brent bartman
PostPosted: Mon Apr 30, 2007 2:27 pm    Post subject: Reply with quote
i dont have to buy a new transimmsion or will the tcase bolt right up????? and instead of buying a new transmisson could i divorce mount the t case
92 XJ
4.0L
pace setter exhaust
AFE cold air
jet chips TBS
PostPosted: Mon Apr 30, 2007 3:50 pm    Post subject: Reply with quote
From a link in the link that was posted earlier http://lists.off-road.com/pipermail/xj-list/2002-February/002053.html
You can swap trannies if you have a good 4x4 version, or if you want to save a few bucks get a worn out 4x4 version of your tranny and use the tailhousing and tailshaft from the 4x4 tranny, hooked to your 4x2 tranny. You have to completely rebuild your transmission to do that, however.
Once you've done either of those options, you would then bolt the transfer case to the transmission.
