Wacky Hazards
PostPosted: Mon May 07, 2007 5:28 pm    Post subject: Wacky Hazards Reply with quote
A buddy of mine recently bought a 97 TJ. When the hazards are turned on only the rear lights blink. I noticed that only the right turn signal indicator on the dash is blinking. When the left turn signal is turned on the hazards work fine. All the bulbs are fine. It's no big deal, cause the hazards will work with the blinker on, but I was wondering if anyone has come across this before.
blktrax
PostPosted: Thu May 10, 2007 10:38 am    Post subject: Reply with quote
My 97 TJ had this problem when i first got it a month or so ago. The front 2 bulbs 3157's I belive, the contacts in the bulb housings were all croded. Got some electrical cleaner, some new bulbs and some dieletric silicone, cleaned them up put new bulbs in, havent had a problem since. I think it was a ground issue back to the relay that was causing the no blink or steady on condition.
Should do the same thing to the side markers as well, bulbs 194's
