93 2.5L YJ won't turn off
YJIan
PostPosted: Sat May 19, 2007 6:20 pm    Post subject: 93 2.5L YJ won't turn off Reply with quote
This may sound strange but, I can turn my key to the off postion and remove it from the ignition and my Jeep keeps running. Any know what might be wrong?? I have to use the clutch to stall the engine to get it to shut off. Any Ideas??
Glowyrm
PostPosted: Sun May 20, 2007 6:33 am    Post subject: Reply with quote
check your alt. wires. Bad ground keep the Alt. from grounding the field, therefore keep making power.
'87 XJ Chief w/tow pack. Dana 30/44 f/r
3.5" lift 4.88 gears NP242 t-case
Numerous junkyrd doodads
31x10.5's
YJIan
PostPosted: Sun May 20, 2007 5:06 pm    Post subject: Reply with quote
Thanks, I'll check that....and now that I think about it, it only happened while I had a small trailer hooked up to it, I wonder would a bad ground from the trailer wires cause this?
kaos
PostPosted: Mon May 21, 2007 12:50 am    Post subject: Reply with quote
In this case I don't see how a bad ground could cause the problem.
However, depending on which lines are taken to your trailer connection, miswiring or faults in that might. If BAT and IGN wires are shorted together anywhere, they would cause this.
Other possible causes are bad or misaligned ignition switch, or bad ignition relay.
HTH
Kári
