Please Help - Stalling
claypoolsgirl
PostPosted: Thu May 24, 2007 11:57 am    Post subject: Please Help - Stalling Reply with quote
Specs: 99 TJ 4.0 sport, manual, 99k miles, recently replaced radiator, thermostat/gasket.
Problem: Stalling when I start the engine after cooldown. Have to press the clutch in on neutral and rev engine. Cannot brake until car registers 210 degrees otherwise engine stalls out. Flushed new radiator, noticed a brown (not milkshake like) water almost rust colored upon the several flushes.
Took battery cables off, tested battery, good. Cables Clean.
Dont know where to go other than the stealership at this point. Can anyone offer advice before I change the following:
Spark Plugs/wires
Dist. Cap
O2 Sensor
(now TPS as well)
thanks!
