Please read. Should be easy to respond....?
cherokeeonly425
PostPosted: Mon May 28, 2007 4:38 pm    Post subject: Please read. Should be easy to respond....? Reply with quote
I have a bell like noise coming from my right front side. Noise is not there during idle but there when I am in motion. Thanks a bunch!
If anyone lives in Washington yall should check out Little Naches!
5.9 andy
PostPosted: Tue May 29, 2007 8:28 pm    Post subject: Reply with quote
is it like a
"ring ring ring"?
"beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep"?
"beep beep beep"?
mabe a little more specifick as to what ir sounds like and where it comes from (brakes, axle, engine compartment) and then when (stoping/slowing down, accelerating, turning, 4 wheeling)
Glowyrm
PostPosted: Wed May 30, 2007 6:03 am    Post subject: Reply with quote
If your having a noise that sounds like a grind then a chiming note then look at your Alt. and your idlers.
'87 XJ Chief w/tow pack. Dana 30/44 f/r
3.5" lift 4.88 gears NP242 t-case
Numerous junkyrd doodads
31x10.5's
PostPosted: Wed May 30, 2007 2:32 pm    Post subject: Reply with quote
I would check the idle pulley.. When the bearing goes out in it it tends to jingle ..(kinda like a bell ringing.. )
