Front Diff. Tag
Leejr57
PostPosted: Fri Jun 01, 2007 6:00 pm    Post subject: Front Diff. Tag Reply with quote
Hi, I'm new here, (my first post). I'm trying to find out what ratio I have in my '96 Grand Cherokee. I have the tag from the front cover, it reads as follows:
52098727
610572-2
From what I've read I'm supposed to be able to tell the ratio from those numbers. Does anyone have any idea what the numbers mean? Thanks for any help.
PostPosted: Fri Jun 01, 2007 6:38 pm    Post subject: Reply with quote
Hello Lee and Welcome!!!
There should be more numbers. Are you reading the tag right? Check the tag for more numbers. Sometimes there is too much paint or crud, scrape off the tag and you should find the ratio. Here is a tag from a TJ I'm working on. I circled the ratio in orange. The numbers you gave are in red. Let me know if you find them. Mr. Green
Leejr57
PostPosted: Sat Jun 02, 2007 4:07 pm    Post subject: Reply with quote
Geez, do I feel foolish!! Thanks for the fast reply. I found the ratio, right where you said it was, under lots of grease and dirt. Embarassed
PostPosted: Sat Jun 02, 2007 4:11 pm    Post subject: Reply with quote
You're welcome! Cool
