2001 4WD Cherokee rear differential noise
docasbro
PostPosted: Tue Jun 05, 2007 9:27 am    Post subject: 2001 4WD Cherokee rear differential noise Reply with quote
I have a 2001 Cherokee 4WD. It is all stock except for a small lift. The rear differential is really loud. I changed the fluid and checked it all out and the gears look perfect and there were no metal shavings. I put in 75-140 synthetic gear oil in. It doesn't make any noise when accelerating only cruising and decelerating, then it gets really loud. It seems to be louder when turning to the right. Any suggestions would be much appreciated. I don't have a bunch of bucks to throw into it right now so I will have to do the repair myself. I can pretty much fix most things with step by step instructions.
Thank you!
cksport
PostPosted: Wed Jun 13, 2007 10:23 pm    Post subject: Reply with quote
sounds like spider gears to me but what do I know i'm only ASE certified
docasbro
PostPosted: Thu Jun 14, 2007 1:33 pm    Post subject: Reply with quote
so How big of a job is it? How do I know what spider gears I need? The tag on the differential only has numbers on it. I appreciate it - Thanks!
