HELP! 1997 XJ diagnostic code 45-OVERDRIVE SOLENOID - FIXED
Tardis
PostPosted: Mon Jun 11, 2007 6:05 pm    Post subject: Reply with quote
Good to hear you fixed the problem. And yes, the AW4 and Toyota A340 trannys are almost exactly the same internally. AW=Aisin/Warner (Japanese Trans Manufacturer). It's too bad the Japanese AW4's outlast the Chrysler designed 42/44RE's they put in GC's 2:1.
98' TJ, 99' XJ
towersXJ97
PostPosted: Thu Dec 04, 2008 1:09 pm    Post subject: almost the same problem Reply with quote
Hi I Hope you friends can help me, I am in the same situation but my Trany doesn’t shift from 4 to 1st, it stars in 1st in the first engine start then when I need to stop and go again doest shift in to 1st it stays in 4, so I used it as manual and it runs good, also my check engine light is on with codes 12, 45, 55.
djgrayxj
PostPosted: Fri Dec 05, 2008 4:33 am    Post subject: Reply with quote
towersXJ97 so you have the AW4 automatic transmission problem?
We need the basic information:
Cherokee ____? Year ___? Engine ___? 2WD or 4WD?
If you have an automatic transmission take the XJ out for a drive that is long enough to warm up the transmission fluid good, then park it on a level surface, place it in park and leave the engine running. Open hood and look fore transmission dipstick (should be located on left side of engine [from front] back near fire wall) remove, wipe of with clean rag and reinsert, remove again and check for the level of the fluid according to marks on dipstick, at the same time look at the color of the fluid red is good, brown and burnt smelling is bad. If red and not burnt smelling but low add in small amounts of fluid until normal level is close to being attained. A little less than normal is OK, OVER FULL IS BAD. Take for another test drive if fluid is added.
Post back what your findings are.
Highlander
PostPosted: Wed Nov 04, 2009 7:31 pm    Post subject: Reply with quote
I know this is an old post:
But was wondering how do I test the Solenoids without opening up the Trans
