Starting problem
chas57
PostPosted: Sun Jun 10, 2007 7:30 pm    Post subject: Starting problem Reply with quote
I have a 96 Grand it won't start. The car will crank but won't start. When I just turn the key to the on position the gas gauge does not move and the low gas light comes on. I think that the security system has a short in it, is there any way I disconnect the Security system. I know I have gas just put $52.00 in it the day before the problem started. I also checked the fuses and replaced the Fule pump relay. And the ASD relay.
Also when using the keyless entry the alarm will not flash on the dash board. If anyone has any suggestions do tell!!!
DankNesS
PostPosted: Wed Jun 20, 2007 11:34 pm    Post subject: Reply with quote
check the fuel pressure to determine if your pump is dead like mine just died
