put a 1990 4.0L into a 1986
skipperiii
PostPosted: Sun Jul 08, 2007 1:45 pm    Post subject: put a 1990 4.0L into a 1986 Reply with quote
I have a 1990xj 4x4 with a inline 4.0L. Will this engine mount into a 1986xj 4x4. Also will the trany and transfer case bolt in as well. Thanks for the help.[/img]
PostPosted: Sun Jul 08, 2007 3:30 pm    Post subject: Reply with quote
the engine will mount in. do you have both auto's? or both manual's or a combination of the two? they should all bolt in . however controls might have to be worked out if you have different transmissions.
you will have to keep the current injection system unless you want to swap over the wiring harness and computer , i would just put the 90 short block in , maybe including the head .
is your 86 also a 4.0L or something else ? if its something else i don't know , i have never owned anything but a 4.0L in a jeep .
skipperiii
PostPosted: Sun Jul 08, 2007 5:34 pm    Post subject: Reply with quote
The 86' has a v6. http://i207.photobucket.com/albums/bb189/skipperIII/scan.jpg
kaos
PostPosted: Mon Jul 09, 2007 2:09 pm    Post subject: Reply with quote
What's more, I read somewhere that when the 4.0L was introduced, considerable modifications had to be made to the Cherokee engine bay, meaning that getting it to fit in older models will be very difficult.
Best regards,
Kári
