stalls whe turning LEFT
RCJP
PostPosted: Thu Aug 16, 2007 9:36 am    Post subject: stalls whe turning LEFT Reply with quote
Hi, i'm havin a problem with my Jeep Grand Cherokee its a 1998 model witha 4.0L 6L engine..
when a turn to the LEFT and step on the gas the car stalls and I have to let go of gas pedal and step on it again but very slowly so it wont stall,
recently it started doing it when iturn right but not everytime...
thank you
Teriod
PostPosted: Thu Aug 16, 2007 10:08 am    Post subject: Reply with quote
check your power steering fluid, or your ps pump is going out
RCJP
PostPosted: Thu Aug 16, 2007 10:47 am    Post subject: Reply with quote
I'll check that wright after work , tell you what happend
thank you Teriod
PostPosted: Thu Aug 16, 2007 5:00 pm    Post subject: Reply with quote
Funny.. Mine did the same thing a while back.. It ended up being the ground cable..
Check yours.. If it has a swollen spot or alot of corrosion that is your problem..
Mine would completely stall out everytime I turned left.. It was very weird..
But its a good place to start..
RCJP
PostPosted: Wed Aug 22, 2007 6:26 am    Post subject: Reply with quote
Hi everyone thanks for youre replys, well it looks like it has been fixed its been two days and it hasent happend again...what i did was I checked the the PS fluid level and i notice that the viscosity of the fluid I was about to put in was thicker so i refield it. I ddint know that the viscosity changed so much...sorry i'm to this stuff..
TNX for the HELP
Teriod
PostPosted: Wed Aug 22, 2007 6:46 am    Post subject: Reply with quote
what kind of fluid are are you putting in it???
RCJP
PostPosted: Wed Aug 22, 2007 7:21 am    Post subject: Reply with quote
I had the jeep for 6 months i dont know what type it had before.
RCJP
PostPosted: Wed Aug 22, 2007 8:46 am    Post subject: Reply with quote
HI i took it down to shop anyway so they can check it out... I told them what happend. They tought it was very strange that the PS fluid would cause the car to stall or turn-off..
PostPosted: Wed Aug 22, 2007 6:52 pm    Post subject: Reply with quote
Hmmmmm.. Ive never had that problem.. When I am low on fluid mine just sqeels real load.. Razz
