New to jeeps is it worth it???
goalie3434
PostPosted: Mon Jul 09, 2007 8:33 pm    Post subject: New to jeeps is it worth it??? Reply with quote
1998 JEEP CHEROKEE 4X4 7k$
4.0L 110,000 R title
All the following parts have been replaced in the last 20,000 miles
Engine
valve seals
valve springs
valve cover gasket
water pump
idler pulley
power steering pump/hose
alternator
starter
electric cooling fan
fan clutch
radiator
thermostat
cooling fan
A/C condenser
Distrubutor cap/rotor
plugs/wires
serpentine belt
battery
fuel injectors cleaned
fuel injector O-rings
Transmission
filter
oil pan gasket
auxiliary oil cooler
outputshaft seal
tranny mount
Transfer Case
Completely rebuilt
new bearings
new seals
correct speedo gear
[ i]Axels/Driveline[/i]
steeringU-joints
rear driveshaftU-joints
front hubs
frontleft ball joint
Suspension/Wheels
Two inch lift
front coil spacers
rear shackles
shocks
31.10.50 dunlop mud rover tires
Steering
tie rod ends
tie rod
drag link
adjusting sleeve
steering stabilizer
exhaust
exhaust manifold
catalyitc converter
muffler
tailpipe
Front and rear O2 sensors
All fluids Changed
Left fender,right fender,header panel,front bumper,front bumper end caps,front grille,hood,tailgate,rear bumper end caps,windshield,professionally painted
Is it worth 7k???
Mad Scotsman
PostPosted: Mon Jul 09, 2007 10:07 pm    Post subject: Reply with quote
Sounds like someone has flogged the piss out of it if all of that has been replaced recently! Shocked Additionally, for $7k it sounds like someone is trying to get back all the money they put in to it for those repairs!
Let's put it this way. I recently picked up a 97 Cherokee 4x4 for what amounts to a song and a dance (wayyyy less than $7k) and it is in really great shape for 141k miles. It's only had a fraction of the maintenance you described for this 98.
Personally, I wouldn't even consider the one you are looking at for that price. For $7K you can probably find one of the last year models (2001) with 50K miles. The Cherokees just don't hold their value like other Jeeps i.e. Wranglers, Rubicons, etc.
monkeyman3875
PostPosted: Tue Jul 10, 2007 5:30 am    Post subject: Reply with quote
Second, that much work can't be good.
-1997 Stock XJ
-4.0 L
-4-speed automatic
old_man
PostPosted: Wed Jul 11, 2007 2:45 pm    Post subject: Reply with quote
WHat HE said.
