Need your advice for LS1 swap
ss 454
PostPosted: Fri Jul 13, 2007 12:26 pm    Post subject: Need your advice for LS1 swap Reply with quote
Hi guys
I am lucky Smile to find this forum and hope to be more lucky Very Happy to have your advice in my coming project .
I have tj 97 (4L engine - AX15 - NP231 - D30 front - D44 rear )
I have serious plan to swap LS1 5.7L with 350 HP . in my jeep and I will make it in my house , I need this jeep for sand dune crazy jeep .
I need yours advice for the four choices I have as follows :
choice #1# LS1 + AX15 by adapter from Novak adapt. or other elss + np231+ d30 front+ d44 rear .
choice #2# LS1 + (4L60E + np241) from youkon 97-03 + d30 front+ d44 rear .
choice #3# LS1 +(nv3550 from xj 00-01 ) +np231+ d30 front+ d44 rear .(( is't true that I can adapter the NV3550 to LS1 by GM Bellhousing without adapter ? ).
choice #4# LS1 + ( from land cruiser fj40 1985 - manul 5 speed transmission + transfer case + axles , very cheap in my country ) .
(( for the first 3 choices : did my tj axle d30 front+ d44 rear will handle 350 hp in sand dune drive ? ))
pls. if you have time give me your advice .
thanks in advance thanks
MANSOR
K.S.A.
silvergoat
PostPosted: Fri Jul 13, 2007 3:49 pm    Post subject: Reply with quote
In the sand your axles will hold up. I sand dragged for several years at pismo beach with the same axles. I ran 33x16.50 paddles in the rear and 33x12.50 bfg muds in the front pushing more horsepower then that plus a bit of nitrous.
ss 454
PostPosted: Sat Jul 14, 2007 12:33 am    Post subject: Reply with quote
Thanks for this experimenter info.
Do you dragged with AX15 also or Auto trans. ?.
What you prefer from the first three choice I have ? ???
Thanks for your support .
silvergoat
PostPosted: Sat Jul 14, 2007 8:19 am    Post subject: Reply with quote
dont remember which 3 speed stick I had at the time. But if your playing in the sand with alot of power i would go with an auto. I really dont know which one to recomend. I'm from the turbo 350 or 400 days.
ss 454
PostPosted: Sat Jul 14, 2007 11:41 am    Post subject: Reply with quote
when you use the th350 or th400 do you have problem with the overheating for the auto trans.? I am fright from this point .
My country is very hot , but I plan to use a used condenser AC from any tj jeep and use it to cool the trans. oil .
Oh for the 3Speed stick , My father have chevy 72 truck 4x4 with 3 speed stick it's make me sick when I drive it , but the true it's very strong gears we loud it more than 1,5 ton , it's our station in camping .
hear sum photo for the chevy72 :
silvergoat
PostPosted: Sat Jul 14, 2007 12:42 pm    Post subject: Reply with quote
No heating problems if everything is done right.
ss 454
PostPosted: Thu Jul 19, 2007 1:55 pm    Post subject: Reply with quote
up
Crying or Very sad
