clutch fork removal 78 cj5
hansw3
PostPosted: Sun Jul 22, 2007 9:21 pm    Post subject: clutch fork removal 78 cj5 Reply with quote
I have not been able to pull the clutch fork on my 78 cj5. How can you separate the fork far enough from the throwout bearing to get the two pins out of the bearing? With the boot removed I can see the throw out bearing. I've put various size screw drivers and pry bars in there. I've also tried inserting them with a come-along disengaging the clutch by pulling the fork back. No luck. I'm pulling my hair out on this one. Surely somebody has a solution short of pulling the entire tranny and bellhousing out in one piece. Then I could pull the fork out with the bearing stuck to it. I really don't want to do that! Any ideas are appreciated.
