no power when hot
utahhandyman
PostPosted: Wed Aug 01, 2007 6:31 pm    Post subject: Reply with quote
today the jeep ran great. no luck on the gas gauge, I'll look at it again this weekend, seems to be a short somewhere.
The vent fan in the cabin is solved also. Symptoms are as follows. Everything worked at idle speeds under no load in gear. With hard acceleration the vent would switch from anysetting, (vent, heat,ac) to the default which is defrost. Shut the engine off and the vacuum system from the reservoir ball to the water diverter would slowly loose vacuum. 2 leaks where found, first , at the diverter and second, between the ball and the firewall.
PostPosted: Wed Aug 01, 2007 7:26 pm    Post subject: Reply with quote
glad to hear you figured everything out .
