Dana 44 Drum-to-Disc brake conversion - list?
PostPosted: Mon Aug 06, 2007 10:20 am    Post subject: Reply with quote
They were cutting costs on a rig they were planning on phasing out.
PostPosted: Wed Aug 08, 2007 3:52 am    Post subject: Reply with quote
I got the quote for the D44 axle shafts in the rear (at $132 per side, not bad), but I was given a quote for $360 AND $460 respectively for the D30 shafts (probably because of the knuckles?). Roughly how much was your front axles, Steve?
PostPosted: Wed Aug 08, 2007 6:11 am    Post subject: Reply with quote
I think I paid around $325...but I talked my way into a deal. While you are at it you should budget in replacing the unit bearings as well. That way you can have complete axle shaft bearing assemblies as trail/emergency spares....
PostPosted: Wed Aug 08, 2007 11:30 am    Post subject: Reply with quote
oh yea those are handy, 3 bolts and the entire hub assembly and axle comes out, after you remove the caliper of course
very quick trail fix
PostPosted: Thu Aug 09, 2007 2:53 pm    Post subject: Reply with quote
These shafts???
http://www.northridge4x4.com/proddetail.php?prod=ALLOYUSA-12148
http://www.northridge4x4.com/proddetail.php?prod=SP-ALLOYUSA-RUBI-REAR
The rears are $225 shipped and the fronts are $550.
PostPosted: Fri Aug 10, 2007 3:33 am    Post subject: Reply with quote
The first is for TJ applications, so they'd be too short. The other should fit though (but says they're for "RUBI", so they may not). I'm trying out Kizer's price-tool to see how much I can get both sets for.
EDIT: Whoops, forgot to mention 30 spline on the rear 44 from the older model XJs... Embarassed
Kizer, can you fix that?
PostPosted: Fri Aug 10, 2007 9:46 am    Post subject: Reply with quote
The D30's in TJ's are exactly the same as XJ's...so they will fit. Same with the D44....TJ shafts are the same lengths.
PostPosted: Fri Aug 10, 2007 10:20 pm    Post subject: Reply with quote
Okay, someone fed me misinfo there. Thanks!!! Mr. Green
Now I gotta gather all the parts up.... Rolling Eyes
