sway bar links
el_dubya
PostPosted: Sun Aug 05, 2007 6:31 pm    Post subject: sway bar links Reply with quote
im pretty sure i have a bad sway bar link, popping when the jeep leans to one side or the other, but i dont know which one. so my question is, are both links the same? they look to be the same, only flipped around, but on the internet sites seem to want to to choose left or right side. id like to buy one, replace it and if it doesnt fix it, switch it to the other side... is this possible? And before you tell me to replace both, im a poor college kid and need to spend as little as possible right now, so dont even mention it. Thanks
Dub
'98 TJ SE
Taurus Fan
Uniden PC68 Elite CB
blktrax
PostPosted: Mon Aug 06, 2007 5:20 am    Post subject: Reply with quote
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=TR1&MfrPartNumber=S18263&PartType=78&PTSet=A
Yes they're the same on both sides. But you're not going to be able to tell witch one is bad till you install one new one. But once you tighten the nut on the top of the link, it presses itself into the bar. If you try to hammer it back out, you could ruin the threads and possibly the spherical joint on the link.
My 97 did the same thing, also needed to replace these too.
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=TRW&MfrPartNumber=HB1788&PartType=77&PTSet=A
